What are the System Requirements for UndeleteOnClick?
UndeleteOnClick requires Windows 2003 and newer or Windows Vista and newer. Windows XP, 2000, 95 and NT are not supported.
Modified on: Fri, 23 Nov, 2018 at 7:06 AM
Send feedback
