SyncBack Touch allows you to create a comprehensive backup of all of your home or business information that resides on computers, mobile phones, tablets or other devices that run Windows, Linux, macOS or Android.
Download Link for All Versions of SyncBack Touch
With SyncBackPro/SE and SyncBack Touch you're in control. There are no problems relating to locked files and administrator rights, and it comes with security built in.
SyncBack Touch is free to use with SyncBackPro or SyncBackSE V10 (or newer). SyncBackPro/SE V9 (or older) versions support 2 connections to SyncBack Touch by default. You may purchase additional licenses to extend the number of SyncBack Touch connections.
If, after reading this article, you're still unsure about what SyncBack Touch is then this article on example uses may help.
SyncBack Touch is a cross-platform service (Windows, Linux, macOS and Android) that allows SyncBackPro and SyncBackSE to remotely access a device's file system in order to perform backup/restore and sync operations.
Install SyncBack Touch on the device you want to access then create a profile on SyncBackPro/SE to copy files to and from that device. For example, backup all your photos as soon as your mobile device connects to your local Wi-Fi!
One of the great leaps forward since SyncBackPro/SE V7 is how both SyncBackPro and SyncBackSE can now connect with SyncBack Touch, and how this allows you to backup not only computers using the Window operating system, Linux (64-bit Intel Linux - Ubuntu LTS 16.04 and RedHat Enterprise V7), Apple macOS (iMac, MacBook Air, MacPro, MacBook Pro etc.) and Android (phones, tablets etc.):
- Installs on Windows, Linux, macOS and Android.
- Create and manage backup schedules directly within SyncBackPro or SyncBackSE.
- Centrally control access to all of your organization's endpoints (computers, laptops, mobile phones tablets or other devices running Windows, Linux, macOS or Android) by managing connection usernames and passwords from within the SyncBack Management Service.
- The Windows service version of SyncBack Touch uses the device's System Account so that it can backup even if a user is not logged on.
Let's take a look at some of the ways SyncBack Touch might help you.
SyncBack Touch In The Home
Let's say you have a family and that in addition to your Windows computer, there are several other devices in your home.
You've bought a license to use SyncBackSE to backup your home computer. Your partner uses an iMac so you download and install the macOS SyncBack Touch App. You've got a wi-fi network at home, and so you run SyncBack Touch on the iMac, then make a new backup profile to backup your iMac in SyncBackSE. Your kids also have an Android tablet so you download the SyncBack Touch App and presto - You backup that too - All for the price of a single license of SyncBackSE!
SyncBack Touch At The Office
You're a business user and have Windows, Linux, macOS and Android devices. If you've only got Windows computers, that's fine too. You buy SyncBackPro V10 (or newer version) to give you Cloud support and the flexibility to backup all your business devices (three computers and Android devices). The beauty is: everything is managed from SyncBackPro.
Using SyncBack Touch
Note that SyncBack Touch requires SyncBackPro or SyncBackSE and will not work with SyncBackFree.
- Create a new Profile in SyncBackPro or SyncBackSE and select the Source (or Destination) as SyncBack Touch.
- On the SyncBack Touch settings page (in the New Profile Wizard or when modifying your profile) click the Find button. By default SyncBack Touch installations require no username or password to access them.
- Click the Test button on SyncBack Touch to verify.
- You can change the security settings of SyncBack Touch on the device itself via the Settings menu. If SyncBack Touch is not on the same local network or it cannot be found, you can enter the IP address and port.
SyncBack Touch provides two types of security:
1. You can optionally set a password so that the connection to SyncBack Touch cannot be accessed via SyncBackPro/SE without the correct password.
2. When using SyncBackPro, you can configure it to use the SyncBack Management Service for validation.
SyncBack Touch For Android Users
If you have an Android device - perhaps a phone, pad or tablet take a look at the following as there are a few things you'll need to do to make sure things run smoothly.
The SyncBack Touch application (available for Windows, macOS, Linux and Android) is free for SyncBackPro/SE V10 (or newer) versions.
If SyncBack Touch device is configured to verify usernames and passwords with an SBMS server (SyncBack Management Service) then you enter your SyncBackPro serial number using the SBMS console:
1. Start the SBM Console
2. Login to your SBMS server
3. Select Service->Register Serial Numbers from the main menu
4. Click the Add button and paste in, or type in, your SyncBackPro serial number
To enter additional SyncBack Touch Licenses in SyncBackPro/SE V9 or older versions:
1. Start SyncBackPro/SE
2. Select Help->SyncBack Touch Licenses from the main menu
3. Click the Add button and paste in, or type in, your SyncBack Touch serial number
If you are using SBMS (SyncBack Management Service) then you enter your SyncBack Touch serial numbers using the SBM Console:
4. Click the Add button and paste in, or type in, your SyncBack Touch serial number
