Modify your profile, enable Expert mode (via the Click For Options button), go to When -> Periodically, tick the "Run this profile every" checkbox and select how frequently you'd like the profile to run, e. g. every 12 hours. Note that if you see some red text saying "Background backups are currently disabled", click on the red text to enable background backups.
Running profiles periodically in the background Print
Modified on: Mon, 26 Nov, 2018 at 9:02 AM
