This article provides information about the above error message, which may appear in the log files when attempting to copy open / locked files. This error may be caused by the one of the following reasons:
  • Insufficient free disk space on the drive that contains the locked file. Try deleting unnecessary files, e.g. temporary files, to create more free disk space. You can also create more free disk space by deleting all restore points except the latest:
    - Run Disk Cleanup and click OK (it does not matter what drive you select). Next, click Clean up system files and select your system drive (usually C:). Next, go to the More Options tab.
    - In the System Restore and Shadow Copies section click the Clean up... button. A message will popup - Are you sure you want to delete all but the most recent restore point? Click Delete. You are prompted again if you want to continue.
    Now, all the System Restore points except the most recent one are cleaned. As a result there will be more free space in hard disk.
  • It can also be caused by other profiles that are being run at the same time and are also copying open/locked files from the same drive. Only one profile can be copying open/locked files at any one time.
  • Some other software may also be trying to access the shadow volume for that drive, e.g. disk defragmenters, other backup software, etc.
Advanced VSS Options
SyncBackPro and SyncBackSE V12 (and later) include advanced Volume Shadow Copy Service (VSS) options that provide reliable copying of open or locked files. These settings allow administrators to select and fine-tune VSS components such as providers, context, and backup type to ensure compatibility with different storage environments and application requirements.
In most cases, the default configuration is sufficient. However, advanced options are available for scenarios that require specific snapshot behavior or integration with enterprise storage systems, such as enterprise RAID systems or SAN arrays. For example, a SQL database VSS provider can ensure that database files are captured in a consistent and complete state during the copy process.
You can access the advanced VSS options from Modify Profile > Expert > Copy/Delete > VSS Settings.
