SyncBackSE/Pro does not start minimized on Windows login
SyncBack will start minimized if set to run on login. If you are using a utility like Startup Faster! then please note it may interfere with the startup process and SyncBack may not start minimized. To resolve this, you must disable SyncBack from starting with Startup Faster!
