We do not recommend or support the use of SyncBackPro, SyncBackSE or SyncBackFree with the Sandboxie program. For example, if SyncBack V8 or older is used with Sandboxie then the Differences window will never appear. There are probably numerous other situations where SyncBack does not operate correctly when used with the Sandboxie software.
Sandboxie and SyncBack Print
Modified on: Wed, 11 Sep, 2019 at 2:36 PM
