Can I run FindOnClick from a USB key or other external storage device?
Yes, you can simply copy the FindOnClick.exe and foc.dll files to the external storage device. Run it from the external device before unplugging it as FindOnClick will automatically copy your settings to the device. Remember you must be an Administrator on the computer you plug the external storage device into to be able to get the best performance from FindOnClick.
