How effective is UndeleteOnClick on an NTFS vs. a FAT file system?
UndeleteOnClick makes a best effort to undelete a file no matter which file system is used. Because of the way the FAT file system works it can take longer to find deleted files.
Modified on: Fri, 23 Nov, 2018 at 7:23 AM
Send feedback
