Amazon S3 - privileges required for custom security policy
If you need/wish to set a custom Security Policy for SyncBackPro with respect to permitting it access to your Amazon S3 account, these should include the following privileges:
GetObject
PutObject
DeleteObject
ListMultipartUploadParts
AbortMultipartUpload
RestoreObject (if using Glacier and need to restore from it)
CreateBucket
DeleteBucket
ListBucket
ListAllMyBuckets
ListBucketMultipartUploads
GetBucketLocation
Note that the privilege ListAllMyBuckets is only required in the profile configuration window so that you can choose from available buckets. If you do not have this privilege then you can manually enter the bucket name in the profile by right-clicking on the bucket list in the Cloud configuration window and selecting Add Bucket from the pop-up menu.
The CreateBucket and DeleteBucket privileges are also only used in the profile configuration window so you can create and delete buckets. If you do not have these privileges then it will not affect the running of a profile.
