If you are using Windows 7 and want to use TLS 1.1 or TLS 1.2 with the FTP functionality in SyncBack then you must first enable TLS 1.1 and 1.2 in Windows. On Windows 8 and higher the protocols are enabled by default.
Note that SyncBack V12 supports TLS 1.3
To enable TLS 1.1. and TLS 1.2 on Windows 7 import the following registry keys and then reboot:
Windows Registry Editor Version 5.00  [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.1\Client] "DisabledByDefault"=dword:00000000  [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.1\Server] "DisabledByDefault"=dword:00000000  [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.2\Client] "DisabledByDefault"=dword:00000000  [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.2\Server] "DisabledByDefault"=dword:00000000
