Please note that it is not recommended that freeFTPd is used with any version of SyncBack. The developers of the server software have no plans to update and fix it. For example, it is not Unicode compatible and is unable to save its own settings on newer versions of Windows.
Use of freeFTPd is not recommended
Modified on: Thu, 22 Nov, 2018 at 5:07 PM
