If you receive the error ‘425 Unable to build data connection: Operation not allowed’ when backing-up files to ProFTPD Server, then change the FTP engine to WeOnlyDo under: Modify profile > FTP page, save the settings and rerun the profile.
425 Unable to build data connection Print
Modified on: Mon, 11 Nov, 2019 at 2:37 PM
