Logo
2BrightSparks Help and Support
Welcome
Login  Sign up
Home Solutions
New support ticket
Check ticket status
Solution home Technical Articles Third Party Programs Compatibility
Using SyncBack with Cryptomator Print
Modified on: Mon, 31 Oct, 2022 at 2:33 PM
When using Cryptomator, it is recommended you use the SERIAL or LABEL variables (in your source and/or destination paths) to ensure you access the correct drive once it is unlocked. The following KB article explains how to use those variables:
https://help.2brightsparks.com/support/solutions/articles/43000335838
Send feedback
Sorry we couldn't be helpful. Help us improve this article with your feedback.
Related Articles
    Home Solutions
    Article views count
