You can enable "dark mode" in the SyncBack user interface by changing the style:
- Click the burger menu at the top-left of the main window in SyncBack (the burger menu is the three vertical lines). A pop-up menu will appear.
- Change the Style to Windows10 Dark or Windows11 Modern Dark.
If you are using a screen reader, or a remote desktop connection (RDP), then the styles menu is not available and the default Windows style will be used automatically. Styles are not supported over remote connections.
To stop using a screen reader, enable the option Stop using screen reader in the Preferences main menu. Note that this menu item is only visible if a screen reader has been detected.
