Support for Egnyte is deprecated and will be removed in a future version of SyncBackPro.
You are strongly recommended to create and use your own API key with Egnyte and SyncBackPro. If you do not then you will be sharing a single key with all users of SyncBackPro, and that will lead to throttling (403 errors).
If you are running a SyncBackPro version prior to V11 (e.g. V10 or V9), then you need to upgrade to the latest release. To upgrade, visit our upgrade store at: www.2brightsparks.com/store/upgradestore.php
Instructions for creating an API key can be found in Egnyte's guide here:
Once you have a key:
- Start SyncBackPro
- Go to burger menu -> Linked Cloud Accounts
- Authorize Egnyte by clicking on the switch next to Egnyte (you may need to scroll down)
- Enter your domain (typically just your company name as one word)
- You are then prompted: Do you have a Client ID/Key and Secret for Egnyte? If not, the default 2BrightSparks values will be used, which may not work. Click Help for more information.
- Click Yes.
- Enter your Egnyte Key and click OK.
- Enter your Egnyte Secret Key and click OK.
- You are then redirected to the authorization web page. Click Allow Access.
- Copy the code displayed on the page, enter it into SyncBackPro, and click OK.
- You will receive a notification saying SyncBackPro is now authorized.
Next, change your profiles that use Egnyte to use your cloud account. To do this:
- Modify a profile that uses Egnyte.
- Go to the Cloud settings page.
- Click Use my Account
- Click OK to save the profile.
