Support for Egnyte is deprecated and will be removed in a future version of SyncBackPro.
If you are using Egnyte then you must contact them to increase your quota, or wait 24 hours for your quota to reset. Egnyte typically gives a very low quota (just 1,000 calls per day) which is often insufficient.
